Touch Control Fluid
Dixieland
11-26-2004 13:34:27
I have been told so many things by dealers, mechanics, farmers, ect;about the right hydraulic fluid for a touch control hydraulic box.
Does anyone know for sure?
bermuda ken
11-27-2004 05:56:10
 Re: Touch Control Fluid in reply to Dixieland, 11-26-2004 13:34:27
Use Hy-Tran Ultra. Anything else will cause problems.
sammy the RED
11-26-2004 22:42:14
Case/IH Hy-Tran.
Novel Idea Guy
11-26-2004 22:30:54
No, nobody knows for sure, at least not since they quit making "Touch Control Fluid," which is what's recommended in the owner's manuals. Even the venerable Hugh MacKay only "votes" for Hy-Tran.
The thing is, it's NOT that critical. Say what you want, but when it all boils down, oil is oil. In this case, it's a hydraulic system, so you want an oil that's suited for hydraulics. That means Hy-Tran if you're talking about Case/IH products.
Hugh MacKay
11-26-2004 16:27:23
Dixieland: I will second the Hy tran. I wouldn't consider anything else. Knock on wood, I have a SA and 130 that have never had hydraulic repair. Been using hy tran since introduced, and before that touch control fluid.
Bigdog
11-26-2004 13:45:42
You can't go wrong with Hy-tran.
