Gene B, question about grill
Frank Stalfire
12-04-2004 05:38:57
HI Gene, CNKS said you might be able to answer whether a grill from a super A will fit a B. any help would be apprieciated
Thanks
gene b
12-05-2004 05:04:32
 Re: Gene B, question about grill in reply to Frank Stalfire, 12-04-2004 05:38:57
The bottom section from a grille off an A will need a small amount trimmed. The small cutout for the As steering sector should not be too noticable when placed on the B.
Jim Becker
12-04-2004 06:20:45
Besides what Dave BN said, there is also a difference between early and late style grills on both models. The fastening system changed.
You might be able to trim an A grill to fit a B. A B grill would leave gaps on an A but might not need trimming. Either way, the wrong grill would probably be obvious.
Frank Stalfire
12-04-2004 06:37:00
 Re: Gene B, question about grill in reply to Jim Becker, 12-04-2004 06:20:45
Thanks for the help guys, I'am pretty good with metal fabrication and wonder if I could do any modifacations to amke it look right, do you think this is possible or is it just to far off?
Dave BN
12-04-2004 06:10:54
I'm not Gene but A and B grills are not interchangeable. The bottom of the grills are different. The B and BN have a pad for the cultivator mount that would be in the way of the A grill. Dave.
parts man
12-04-2004 15:40:32
 Re: Gene B, question about grill in reply to Dave BN, 12-04-2004 06:10:54
An A grill also has a round cutt-out to go around treh steering box that the B and BN don't have. A C grill will fit, but a super C won't. (taller)
