Bushing material
John in Ct.
12-05-2004 18:52:46
While working on my H, I sometimes can fix a worn part by drilling a hole out to a little bigger size and inserting a bushing. Rather than go to a machine shop to custom make a bushing, does anyone know who sells standard size bushing material that I can cut to length and press in?
lee
12-05-2004 19:28:39
 Re: Bushing material in reply to John in Ct., 12-05-2004 18:52:46
What a bunch of hackers LOL
John in Ct
12-06-2004 06:12:37
 Re: Bushing material in reply to lee, 12-05-2004 19:28:39
I think you misunderstand. There are parts on my H that are worn. New parts are no longer available. I can't locate NOS parts. Used are worse than mine. Every aftermarket part I get is not made as well as the origional. Example, my throttle lever was a little worn in the hub. I got an aftermarket one and it isn't made like the origional and the quality wasn't there too. I put a bushing in my origional one and it is better than a new aftermarket one and I am good to go. A machine shop can bore out a hole then turn a custom bushing but sometimes that precision (exact center or hole size) isn't necessary and an off the shelf bushing will work just as well.
lee
12-06-2004 07:53:09
 Re: Bushing material in reply to John in Ct, 12-06-2004 06:12:37
Just joking a little.
riverbend
12-05-2004 19:22:52
For small, light duty bushings try brass or copper tubing. If the tubing OD is a little oversized for the hole, you can press it in with a vice and redrill the ID. If the bushing is trapped, you can slot it and make it a little smaller too. If it is not quite a press fit, try a little Loctite 505 (?) - the green stuff.
Gerald J.
12-05-2004 18:57:46
Also Baum Hydraulics, I think www.baumhydraulics.com
Gerald J.
Bob
12-05-2004 18:55:29
Try:
www.mcmaster.com
