Looking for a Live hydraulic pump for Farmall H
Jaysen
12-06-2004 08:28:44
Hey Guys,
Can anyone help me locate a live hydraulic pump for a Farmall H? Looking for a non-belly pump style.
Thanks,
Jaysen
Nebraska Cowman
12-06-2004 11:36:05
 Re: Looking for a Live hydraulic pump for Farmall in reply to Jaysen, 12-06-2004 08:28:44
interesting. I sold a Super H pump on ebay a couple weeks ago and the party found out it would not fit their H. (I did not know what tractor they were buying it for) Well anyway when they emailed me I told them I would refund if they wanted to return the pump so I may have one for sale again.
Allan in NE
12-06-2004 09:32:39
Jaysen,
Check your serial number. On older tractors you have to change out the front cover and the timing gears.
If memory servers me, it was midway in '51 at about # 32xxx or something like that. Everything newer will bolt up. I can look it up if you need the split point.
Allan
Jaysen
12-06-2004 11:43:36
 Re: Looking for a Live hydraulic pump for Farmall in reply to Allan in NE, 12-06-2004 09:32:39
Thanks Allan,
What do you have to change the front cover out to?
I believe that this is a '39 or '40 model. I am helping out a friend who owns the tractor.
Thanks,
Jaysen
Novel Idea Guy
12-06-2004 13:19:35
 Re: Looking for a Live hydraulic pump for Farmall in reply to Jaysen, 12-06-2004 11:43:36
You have to change the front cover and timing gears to a post 1951 version. A set off one of the last Hs, a Super H, 300, or 350 will work.
Don't jerry-rig it. You'll be sorry.
Jaysen
12-06-2004 09:14:34
Thanks,
I have one of those already and the bolts are not lining up. may have to jerry-rig it.
Jaysen
bigdiesel
12-06-2004 09:12:57
I have a M&W live hydraulic pump , hoses and outlets for a distributor mounted pump on a Farmall, $450 if interested
Jaysen
12-06-2004 09:18:23
 Re: Looking for a Live hydraulic pump for Farmall in reply to bigdiesel, 12-06-2004 09:12:57
Is it possible to get a life-sized bolt pattern to make sure it lines up.
Thanks,
Jaysen
Allan in NE
12-06-2004 08:32:44
Here ya go Jaysen. Hope the link works.
Allan
