715 COMBINE
TURNEY
12-12-2004 12:51:51
what deisel moter does the 715 combine have in it and will it bolt in an 560
K.B.-826
12-12-2004 19:26:31
 Re: 715 COMBINE in reply to TURNEY, 12-12-2004 12:51:51
Early 715's had the 301 diesel, which is the same design as the 282 diesel and 263 gas found in the 560. It will only take small changes to make it bolt up. Basically, you just need the correct front cover, front plate, and rear plate. Late 715's had the 310 German diesel, which will not work without major changes.
ejr
12-12-2004 14:03:01
That would be 301diesel or the 301gas the later 715 used the german diesel.I have installed a 301 diesel in one of my 560's and now I'm working on putting a 301 gas in my 460 both where out of combines.
