motor runs cold 434 international
R baker
12-19-2004 15:28:42
the carb freezes the manifolds are cold when running.I built a shrowd but did not help.please help!!
joispoi
12-19-2004 16:04:50
 Re: motor runs cold 434 international in reply to R baker, 12-19-2004 15:28:42
Is the engine running rough? water in the gas?
R baker
12-19-2004 18:55:21
 Re: motor runs cold 434 international in reply to joispoi, 12-19-2004 16:04:50
the motor has no power because the carb is iced.When it is warm outside it runs great
joispoi
12-20-2004 05:55:49
 Re: motor runs cold 434 international in reply to R baker, 12-19-2004 18:55:21
this is a shot in the dark, but try adding dry gas to the fuel, spray down the carb with carb cleaner (this should de-ice it) and see if it happens again. Also, check the air filter, make sure it's clean and free of water/ice. good luck!
