hydralic reservoir
iester
12-21-2004 16:03:31
going to drain,remove and check screen on my 350u. should i use any type of sealer on gasket.thanks
TDK
12-21-2004 21:48:55
 Re: hydralic reservoir in reply to iester, 12-21-2004 16:03:31
The screen is under the reservoir. Unhook lines to reservoir,unhook lines to valve(s) or remove valves altogether. Either 8 or 10 bolts hold reservoir, remove them and raise reservoir STRAIGHT up so screen is not damaged. Loosen 1 1/8 nut holding screen & remove. If screen is not damaged, cleaning will do.Replace o-rings on screen and valves(if removed). Reservoir gasket & o-rings are still avaliable from dealer. Last time I checked the screens cost $65.00, so take care!
Charlie M
12-21-2004 16:49:46
I just did the reservoir on my 300U and didn't use any sealer - just the gasket. No leaks so far.
PAULIH300
12-21-2004 17:00:25
 Re: hydralic reservoir in reply to Charlie M, 12-21-2004 16:49:46
I was told earlier that to clean the screen on a 300U you had to open the top of the tank (where the seat bolts down).It just bolts down right? Any surprises?
iester
12-21-2004 17:20:31
 Re: hydralic reservoir in reply to PAULIH300, 12-21-2004 17:00:25
top is pretty heavy.read where to raise straight up,not to damage screen
