Q for Bob M or others - diode in 3-wire, starter s
Dave in CT
12-21-2004 20:15:11
I want to switch my one-wire Delco 10-SI setup to a three-wire system on my '47 H. I don't have a key ignition switch - just the start button and the shut-off switch. To make the change I'm thinking I need to:
1) Wire the '2' terminal on the alternator to the 'BAT' terminal on the alternator with a 16 or heavier gauge wire.
2) Using 16 or heavier gauge, wire the '1' terminal on the alternator to the same side of the shut-off switch that holds the wire that runs to the '+' pole on the coil. Would it make sense to wire both a diode (Radio Shack PN: 1N200X - where X is 1-4) _and_ a warning light (bulb# 161, 194, 1813, 1815) in this line? My primary concern is to avoid running down the battery but having the warning light as well would be nice.
I was also wondering what the benefits would be to wire a solenoid in between the plus terminal of the battery and the starter. Currently I have 4/0 copper cable running from both the plus terminal of the battery and the starter to the start button. Putting a solenoid in would cut out a two or three feet of cable but, with that size cable already in place, would it make much difference?
Thanks for your time.
Bob M
12-22-2004 04:23:48
 Re: Q for Bob M or others - diode in 3-wire, start in reply to Dave in CT, 12-21-2004 20:15:11
Dave - To your questions:
1 – As the others suggest below, for the #2 terminal wire you can use as small gage wire as is mechanically possible. (#2 is the voltage sense terminal for the internal regulator. It carries only a miniscule amount of current - something on the order of 1 milliampere.)
2 – Use either a warning light OR a diode, but not both! No need to worry about draining the battery when shut down thru the warning light – the system is specifically designed to work with the light. However if you are concerned about the warning light burning out and disabling the alternator while running, you can wire a 15 to 30 ohm, 2 watt (minimum) resistor in parallel with the lamp.
3 – You sure you’ve got 4/0 primary wire there and not AWG #4? 4/0 is HUGE - like ½” iron pipe. Anyway, with cable that heavy you certain won’t need to add a solenoid to reduce the cable length – the extra couple feet of cable is inconsequential!
Hope this helps...
Dave in CT
12-22-2004 07:54:12
 Re: Q for Bob M or others - diode in 3-wire, start in reply to Bob M, 12-22-2004 04:23:48
Must be AWG 4 - sorry about that. I really wanted to get this question out last night and couldn't see the writing on the wire too well by the flashlight. It's copper and a little under 3/4" in diameter with the insulation. Still plenty heavy enough to avoid doing the solenoid installation.
Thanks for your quick reply. How do you view the benefits of an oil pressure switch vs. a diode in this application?
Bob M
12-22-2004 10:10:19
 Re: Q for Bob M or others - diode in 3-wire, start in reply to Dave in CT, 12-22-2004 07:54:12
AWG #4 sounds a little more reasonable! As long as the starter cranks smartly and the cable doesn't get warm, #4 primary cables will work fine for you.
To your question my vote is for the diode. It's cheap (less than a buck) and correctly installed is pretty much bullet-proof. An oil pressure switch on the other hand will cost probably $20, needs to be plumbed in, is subject to leak, and if it sticks "on" you'll never know it until you discover the battery is dead some morning.
My PERSONAL preference however is for the warning light! Not only does it tell you the instant the alternator stops charging, it'll also warn you immediately if the fan belt breaks or the water pump siezes - a nice feature when people other than myself operate my tractor!
Dave in CT
12-22-2004 18:29:15
 Re: Q for Bob M or others - diode in 3-wire, start in reply to Bob M, 12-22-2004 10:10:19
Good. Not to make this thread go on forever but, I was trying to keep the description of my setup simple. I actually have a voltmeter installed now so, I can tell when something goes awry. In fact, it was having the voltmeter that called my attention to the fact that the alt doesn't start charging, with the one-wire setup, until the revs are brought up high. I don't always remember to do that with the little jobs I've been puttering around with. I don't need to worry about that with the three-wire setup - that's why I'm going down this road (in addition to wanting the drain protection). I picked up the diode from Radio Shack today. It's tiny. What would be your recommendation for mounting it - just solder it in-line and tape and do a heat-shrink tube over the splice? The reason I go for heavier than needed wire is, mechanically, it'll withstand some knocking.
Thanks again for your time.
Doug in OR
12-21-2004 21:50:32
First of all, the wire from the number 2 terminal is a bit heavy. As Bob said, you can get by with lighter wire - probably down to 18 AWG. This wire is merely a voltage sense and carries no significant amperage to worry about.
As for the diode - I think you are referring to a 1N400x diode. The 'x' is the PIV rating. A 1 means 100 volts... 2 means 200 volts... etc. The most common size you will find at Radio Shack is the 1N4003. This is plenty of diode.
As for the lamp: This works and is a good idea. Short of installing a voltmeter, the lamp is the single best way to determine if your alternator is charging. In reality, if you use the proper size lamp you would not even need the diode. The lamp will drop enough voltage when you shut the tractor down and your back feed will not be enough to fire the coil. Remember that a silicone diode (don't even think of putting a germanium diode here) drops .6 volts in the forward bias mode. This may or may not affect where your alternator starts charging when you also have a lamp in series with it.
As for the solenoid..... I wouldn't bother with it. Besides, 4/0 wire is plenty heavy. How do you even bend that stuff? You have more than enough of a hunk of cable between your battery and your starter - I wouldn't cobble it up with a solenoid.
Bob
12-21-2004 20:41:47
The wire size to the #1 terminal is NOT that critical. Even lighter will do.
If you don't like the idea of adding a switch to excite the alternator (and having to remember to turn it off), get a 2-terminal N.O. oil pressure switch that turns on at low pressure, and hook it in-line between a source of battery voltage, and the #1 alternator terminal.
When the engine is up and running, there is then voltage to the "excite" terminal, and when the engine stops and there's no oil pressure, the voltage to the "excite" terminal on the alternator shuts off.
BobM has a diagram posted showing the hookup of thoil pressure switch. The use of the "idiot lite" with the oil pressure switch is OPTIONAL. The system will work with or without it.
Bob
12-21-2004 20:41:49
