super W4
Lindsay
12-22-2004 08:48:44
My old tractor started to knock , lts been burning oil for a couple of years and fowling the two central cylinders with oil deposits and carbon, the tractor is in excelent condition so ld like to rebuild it , but am not sure to what extent l should plan on going.To my knowledge its never been touched internally.l have not been able to get a rebuild engine manual for the super W4 do l order a rebuild manuale for the super H since they have the same engine ,what obsticles might l run into.Any insight sent my way would be greatly appreciated.
Thanks to all and Merry Christmas.
ps l use the tractor for log skiding and belt drive my old planer/moulder
Bill Vanderstyne
12-23-2004 05:42:45
 Re: super W4 in reply to Lindsay, 12-22-2004 08:48:44
I have rebuilt both a W-4 and an OS-4 and thay are the easiest tractors to work on. I did complete overhauls and never removed the engines. I have a manual that I can copy and send to you if can not locate one but the engine manual for an H should be the same.
Bill
Lindsay
12-24-2004 01:49:02
 Re: super W4 in reply to Bill Vanderstyne, 12-23-2004 05:42:45
Thanks for the responce , thats much better news than l counted on.l may take you up on the manual for the super W4 ,but l will look alittle more for one first.Have a great Christmas
EricB
12-22-2004 10:13:02
Lindsay
1: The reason your #2 and #3 are in rough shape is water leaking down your muffler. It tears apart the valvues and #2 and #3 cylinders. We've all been there!
2: If you are getting knock, that sounds like bearings. However check your oil pressure. If its good you may not have to open the engine. Sleeves and pistons can be done with the engine in place. But when you undo your connecting rods, mark the bearings carefully, so they go back in the same.
3: I have always used a machine shop to check the head and do the valve seating.
As far as manuals go, there should be a lot of them out there. I got mine 35 years ago form the IH dealer.Perhaps others can help you there.
If everything else is in good shape its well worth doing. I have rebuilt mine twice in its 60 yars of history. I use it almost every day. There's a photo of it in the gallery.
Lindsay
12-24-2004 02:02:20
 Re: super W4 in reply to EricB, 12-22-2004 10:13:02
Thanks for the insight ,it terrific. The oil presure shoots right up till the tractor gets warmed up and then it gradually drops off , this has been a slow but steady progression over the past couple of years.Unfortunatly this summer the old girl really had a rough couple of days skiding logs ,as l had to build a lane up through the bush and was pressed for time ,l left the heavy skiding for the large tractor ,but the super W4 could get right in close to hook up and skid the timber to the Ford.Thanks again ,and merry Christmas.
