Order Farmall Cub Parts Online
1949 Farmall Cub
Mitch the Farme
01-07-2005 07:48:27
Need some advice on a 1949 Cub I bought for my grandson. The Cub has been setting in a barn for about 7 years. Tires are dry rotted, but metal etc. is good. Got it running, and oil when we changed it was thick as molasses. Put in 30w HD and changed the oil filter, it's smoking but seems to run good. Left axel seal is leaking, and would like to know if I should flush the engine or check the oil pump to make sure the screen is clean. Oil pressure went all the way up and dropped to almost "O" after running for a little while. What is normal oil pressure? This is first Farmall to own. My grandson is very excited about the tractor. If we have to put new rings etc.,what do you think it would cost? Any advice would be appreciated.
scruffy
01-08-2005 18:25:42
 Re: 1949 Farmall Cub in reply to Mitch the Farmer, 01-07-2005 07:48:27
I have four cubs that I use for full time veg. farming, all were given up for dead by the previous owners. I would use her a bit and change the oil and filter a bunch of times, quick and often. The heavy duty oil, if it's rated for diesels, might clean her out alot. It may have been run on old non-detergent and there can be lots of sh%# in there. If it has good presure at start-up and drops at operating temp, I would think the connecting rod bearings may be worn. I would run her in the summer with SAE 40 and see what you get but should have 10-15lb. at least when hot. If I have an oil presure worry, I alway change gauges to see if the readings are consistent and not just a finicky gauge. If you don't want to do a complete o/h, you could just drop the pan and change the rod bearing for about $40. Won't give you more horses but should up the presure to safe range. You can clean all the old sludge out and check the screen then too. Best of luck keep those girls going!!!!
Mitch the farmer
01-07-2005 12:33:09
 Re: 1949 Farmall Cub in reply to Gene, 01-07-2005 09:18:00
Gene- Thanks for the infor. I'll give it a try.
