IH 574 Tractor hydraulic bleeding
Marshall
01-07-2005 11:23:56
I have an IH 574 tractor and would like to know how to bleed the system. I believe I have air in the system because of the noise that it makes, especially when it is cold.
JB2
01-07-2005 14:18:26
 Re: IH 574 Tractor hydraulic bleeding in reply to Marshall, 01-07-2005 11:23:56
Hi Marshall, the first indication of air in the hydraulics on that style of tractor is spongy brakes or having to pump the brakes.
How cold is cold, -20F, 0F ?
My brother uses his 495D (same hydraulics) every day to feed round bales. The hydraulics make some noise when it starts but last only a couple minutes and that is in -20F weather.
I would check your hydraulic filter and the hydraulic fuild for water or ice cyrstals. Although IH Hytran is supposed to have an anti-water agent.
I believe the noise you hear is the hydraulic fluid being forced thru the relief/bypass valve.
Good luck
JB2
