Confused by an A
Seb.
01-10-2005 17:18:45
Iam a little confused and could use some straighting out. Is their an AV model and also a Super AV Model or are they just all called an AV?
gene b
01-10-2005 17:48:24
 Re: Confused by an A in reply to Seb., 01-10-2005 17:18:45
Both AV and SAV
Mike@NY
01-10-2005 17:23:05
Yes, there is an AV Model, and a Super AV model. The Super AV has the Hydraulic lift. And also the Super AV-1 (at least according to the book I am looking at at the moment). The Super AV-1 had the C123 engine, where the others had the C113. I am sure others can provide more details. Good Luck.
Mike@NY
Hugh MacKay
01-11-2005 04:43:10
 Re: Confused by an A in reply to Mike@NY, 01-10-2005 17:23:05
Mike: You pretty much nailed it. Not a whole lot more to add unless you want to get into serial numbers, casting codes and part numbers.
Zac
01-10-2005 19:12:03
I am also confused. I have a Super A, what is the diff between an A, Super A, AV and Super AV?????
James H in Tx
01-10-2005 19:25:15
 Re: Confused by an A in reply to Zac, 01-10-2005 19:12:03
The A has 15 inch front wheels and 24 inch rear. It does not have hydraulics. The super A has the same wheels but it has hydraulics. The AV has taller king pins, 19 inch front wheels and 36 inch rear. It"s a High Crop. The super AV has the same as the AV but has Hydraulics. It"s also a High Crop.
James in Tx
James H in Tx
01-10-2005 19:24:29
James in Tx
