Electrical Wiring-12 volt Super A
KenSWLA
01-12-2005 19:24:49
What is the purpose/use of the warning light on the 12 volt conversions? I have two Super A's and a C without the lights. Am I missing something and do I need to install the lights?
KenSWLA
01-13-2005 10:17:59
 Re: Electrical Wiring-12 volt Super A in reply to KenSWLA, 01-12-2005 19:24:49
Thanks for the replies. Now I must determine which solution. I also have an Ford 8N and assume it is wired with a lamp, switch, or diode also??
Hugh MacKay
01-13-2005 03:03:04
Ken: I have a SA, 130 and 140, and like you I have no light. I replaced them all with a push button type switch, which I can push to excite the alternator after starting. The push button switch also prevents the back feed. I found the light to be troublesome, either burned out and 60% of time it didn't stop tractor anyhow. One of my push button switches has been going for 11 years with no problem. By the way this is a starter type push button switch and just goes in place of light.
OLDMAN
01-12-2005 19:36:41
THIS IS TO MAKE IT SHUT OFF
SO THAT THE ALTERNATER IS NOT BACK FEEDING THE COIL AND IT STAYS RUNNING OFF THE ALTERNATER
KenSWLA
01-12-2005 22:01:52
 Re: Electrical Wiring-12 volt Super A in reply to OLDMAN, 01-12-2005 19:36:41
Thanks for the information.
Ken
JH in Ohio
01-13-2005 05:35:59
 Re: Electrical Wiring-12 volt Super A in reply to KenSWLA, 01-12-2005 22:01:52
I use a diode of sufficient ratings for the same purpose. That way I don't have to do anything.
Jack
Robbie6
01-13-2005 07:06:23
 Re: Electrical Wiring-12 volt Super A in reply to JH in Ohio, 01-13-2005 05:35:59
I agree with you. I just finished wiring up a Super C and used a diode instead of the light
Robbie
KenSWLA
01-13-2005 07:11:30
 Re: Electrical Wiring-12 volt Super A in reply to Robbie6, 01-13-2005 07:06:23
Would you give a part number and source for a diode?
Robbie6
01-13-2005 08:06:42
 Re: Electrical Wiring-12 volt Super A in reply to KenSWLA, 01-13-2005 07:11:30
Haha!
Can't give you a part number as I drug it outta my old coffee can, it has probably been in their for 20 years! But I did have it labelled (must have been thinking of my old age!) as 1 amp, 50V diode.
Got a Radio Shack near you? The whiz kids there may be able to find you one with that rating.
Give me a shout if you need more info.
Robbie
Bob
01-13-2005 09:37:23
 Re: Electrical Wiring-12 volt Super A in reply to Robbie6, 01-13-2005 08:06:42
A 1 amp 50 PIV diode MAY work, but I'd use AT LEAST a 2.5 amp @1000 PIV diode to be on the safe side. Those are $1.50 or LESS each, anyway.
