6=8=12Volt
Chris in SeMo
01-16-2005 11:53:11
Got an old H Farmall that didn't do well with original 6 volt system, I could usually beat it using the hand crank.Tried 12volt for awhile and it started fast but I didn't like the way it banged so hard on the flywheel when it engaged,plus since it runs on mag I didn't hook it up to the charging system and didn't have to do any conversion but would need to charge it occasionally. Decided to try 8 volt instead and it did well enough and hooked up to charging system OK.I read an article here on YT forum that taught me quite about the original 6 volt system.It said if the starter switch gets hot while cranking you're putting fire directly into the ground.I put on a new starter switch and the big battery cables and a new 6 volt battery and was amazed at the difference.It even started Christmas week at 5 below zero!It was about too cold for the tractor to run after starting.It sounded like one cylinder for several minutes then suddenly began to smooth out.I guess my point is the 6 volt these old tractor were built with is entirely sufficient if all the components are right.Hope this helps someone,Thanks.Chris in SeMo.
lee
01-17-2005 10:29:54
 Re: 6=8=12Volt in reply to Chris in SeMo, 01-16-2005 11:53:11
I've seen that before with tractors on steel. You can see and smell the smoke at the base of the wheels where the fire was put quite literally, right into the ground. That's why they went switched to rubber tires.
Bob
01-16-2005 12:52:11
I don't quite know what you're getting at with your comment about "putting fire to the ground".
Typically, if a component such as a switch heats up it is because of a poor (high resistance) connection, and cleaning up the connection will eliminate the excessive heating, as well as improving performance.
chris in SeMo
01-16-2005 14:11:50
 Re: 6=8=12Volt in reply to Bob, 01-16-2005 12:52:11
Good point Bob,The switch I replaced had the insulation worn away and when the contacts were pushed down they contacted the matching contacts AND the ground.More of the 12 volts were going into the ground than what was being sent to the starter. Thanks,Chris.
farmalljim10
01-16-2005 12:08:28
My H is really good on a 6 volts group 1 battery .The only problem I ever have with 6 volt is if they dont make the propper size battery any more..Other wise keep them tuned up and all conections bright and tight..If they start going to slow find the real problem dont just jump them..Jim
