Order Farmall Cub Parts Online
plowing snow with a cub
jab
01-18-2005 13:17:58
im thinking of buying a farmall cub as a projct tractor. Before i buy i need to know if a farmall cub is any good for plowing a limited amount of snow. Most likely i will end up filling the tires.
thanx
jab
Buzzman72
01-19-2005 05:47:43
 Re: plowing snow with a cub in reply to jab, 01-18-2005 13:17:58
In my experience, once you get those front tires about 2"-3" off the ground, you can plow as much snow as a Cub will physically push [steer w/the brakes in that mode, y'know].
Bill Vanderstyne
01-19-2005 03:44:58
I used to have a '48 Cub with weel weights and no fluid but that little thing would push more snow than you would it could. Real good little tractor for whatever we tried to do with it.
Farmer Bob
01-18-2005 19:02:29
third party image
Works for me. This is my '64 with a Cub 54A blade, chains, no fluid, wheel weights all around.
EZ
01-18-2005 18:55:27
jab,
I would not trade my "49 Cub for anything right now. I"ve been using it to push snow for 2 years now. Wheels weights front and back and a good set of chains will work wonders. 250" to 300" of drive, most of it 2 cars wide. We are right up in God"s Country, Northern Ontario, lots of white stuff! Cold too, -45F all weekend, no snow when it"s that cold.
the tractor vet
01-18-2005 15:29:18
I had a cub when i was a kid it had a plow and wheel weights and tires loaded and chains and also a heat houser i thought i had a D9 cat and we use to get snow it would go thru anything we ever got , my buddy had a Gravly he had to walk in the cold doing drives Not this old boy i got to ride and with comfort thoes 5 dollar a drive with the cubby virus the 5 he got was alot easier.
Novel Idea Guy
01-18-2005 14:11:15
BTW, chains and at least one set of wheel weights are a must. Loading the tires on a Cub, IMHO, isn't worth the time. You really can't get all that much water in there. It'd take 18 gallons of water to equal one wheel weight. You'd be lucky to fit 5-6 gallons in the tiny tires on a Cub, in my estimation.
Tractor Dan
01-18-2005 15:06:16
 Re: plowing snow with a cub in reply to Novel Idea Guy, 01-18-2005 14:11:15
with 8.3x24 tires you can get 13 gallons in each tire with calcium and water mix thats about 131 pounds per tire so 262 pounds of extra wieght will be well worth it
badboy1950
01-18-2005 16:36:52
 Re: plowing snow with a cub in reply to Novel Idea Guy, 01-18-2005 14:08:30
go for it.
