SW6 horsepower
shawn draper
01-22-2005 12:26:13
can anyone tell me the horsepower of a SW6 , want to put a snowblower on it and need to know how big I can go thanks shawn
Haas
01-22-2005 14:26:31
 Re: SW6 horsepower in reply to shawn draper, 01-22-2005 12:26:13
I think CNKS is right about the W6 being too fast for a snow blower. If you only have snow a couple feet deep, find yourself a front blade for it. I would think a W6 would be a real snow pusher with the right blade.
shawn draper
01-22-2005 15:14:16
 Re: SW6 horsepower in reply to Haas, 01-22-2005 14:26:31
Thanks for info , I have a blade , pushes like hell its great but want to put a rear mount blower on it for the times that it would be better , as we in sask canada get a H**L of a lot of snow here ha ha , by the way it -40 today with the windchill, BRRRRR RRRR , will be making a 3pt hitch when I find plans for it,
Sodlinger frooze in Sask Canada
CNKS
01-22-2005 17:46:40
 Re: SW6 horsepower in reply to shawn draper, 01-22-2005 15:14:16
3-point hitches on a W series aren't very feasible because of the seat location. But, if you are VERY good at fabrication, maybe so.
CNKS
01-22-2005 12:39:03
Factory spec is 42 drawbar, 47.5 pto, unless it has a higher hp kit in it. Power is not the problem, I believe you will find that your tractor will not run slow enough for a snowblower, particularly if it is very deep. First gear is 2 5/8 mph, more or less depending on tire size. You probably need a speed about half that.
