Farmall B steering shaft*!@**
Dixieland
01-25-2005 15:29:56
I have to change the front oil seal on my engine and having a heck of a time getting the steering shaft seperated so the worm gear can be removed. I would leave it except I want to replace the shaft bushing. The ony thing I have not done is heat it up. Drilled out the swedge pin in the shaft but it will not budge. Any body got any suggestions???
captaink
01-26-2005 06:25:26
 Re: Farmall B steering shaft*!@** in reply to Dixieland, 01-25-2005 15:29:56
I'm fond of using vibration from an air-hammer. Seems between penetrating oil and vibration a lot of stuff comes apart without busting up my hands, which is a good thing. :>)
Steve W (NY)
01-26-2005 05:48:46
third party image
I just unbolted the one bolt on the steering support, and laid the sterring wheel assembly off to the side. I used a 3-point hoist to pick up the unbolted bolster as a unit, saving a split. Of course if the bolster leaked, I would have done it your way. That seal leaking sure made a mess, and presented a challenge.
This pic ought to explain it.
Take Care,
Steve
Dixieland
01-26-2005 15:33:14
 Re: Farmall B steering shaft*!@** in reply to Steve W (NY), 01-26-2005 05:48:46
Thanks Steve. I had to replace the bushing and seal in the steering worm. I had a dadgum hard time with it. I had to heat it up and still pound the heck out of it. But I was"nt gonna give up. I also had to replace those two washers and seal in the steering gear box. That was a pretty good challange too. If you have any questions or need my help please let me know.
Thanks,
Rex
Shaggy
01-25-2005 21:54:25
I had the same problem with my B. I used some PB Blaster and had my neighbor pull on the steering wheel while I rapped the knuckle with a hammer. It worked but the neighbor about fell on his butt when it let loose.
