300 utility ipto
randy
01-30-2005 15:52:06
posted a question a couple times about not being able to stop the pto from turning.I removed the whole pto assy. from the tractor and disassembled found the bands inside to be in good condition but after reassembly and ajustmet I still could not get the darn thing to stop. after several calls to local and out of state dealers no one could give me an answer. so I remove the small cylinder on the side of the pto and took it apart cleaned and oiled then reassembled .. now the pto works properly...hope this litte info works for someone else with the same problem .. Randy
Ida Red
01-30-2005 20:37:33
 Re: 300 utility ipto in reply to randy, 01-30-2005 15:52:06
I have a good IHC front end loader for your tractor.Red
Irv
01-30-2005 16:54:10
Thanks, Randy - I have been screwing around with that for years - Ill try that out asap. Irv
B Watson
01-30-2005 16:31:54
Thanks, been having a similar problem with mine and thought it might be worn locators for the two lock positions, but now I've got something simpler to try first.
Thanks
