IH 634 Key Switch
DavidP, South W
02-03-2005 16:41:01
We have a 1970 IH 634 UK model tractor that has been on stop for about 20 years. The heater position on the key switch is faulty. A new switch has arrived from McCormick but it is of the type fitted to most tractors, MF, Ford, Case etc with an 'Off', 'Ign', 'Heat' and 'Start' positions. The wiring layout is different to the original. Can anybody out there in IH land help with whatever modifications need to be made at the switch?
Thanks in anticipation.
David P.
JOSSETTE
02-03-2005 16:53:34
 Re: IH 634 Key Switch in reply to DavidP, South Wales, 02-03-2005 16:41:01
most of the switches have little letters on the back of the switch where the wires hook up. B = battery
S=starter I= ign and so on. your two switches should be the same on the back.
David P, South Wales
02-04-2005 10:45:59
 Re: IH 634 Key Switch in reply to JOSSETTE, 02-03-2005 16:53:34
Hi Jossette,
Thanks, I'll have a look. I'm more concerned about making sure that the heater glow warning and plugs are connected correctly.
David P
JOSSETTE
02-04-2005 18:40:27
 Re: IH 634 Key Switch in reply to David P, South Wales, 02-04-2005 10:45:59
sitting that long you might want check the plugs and make sure the element is still there or half way burn off.
DavidO, South Wales
02-05-2005 10:33:58
 Re: IH 634 Key Switch in reply to JOSSETTE, 02-04-2005 18:40:27
Hi again,
All plugs are OK, at least have continuity through them. Injectors have been overhauled but a little uncertain on the wiring changes for the new switch. Again, any help much appreciated.
Cheers
David
JOSSETTE
02-05-2005 10:59:36
 Re: IH 634 Key Switch in reply to DavidO, South Wales, 02-05-2005 10:33:58
explain what you have.
more wires than terminals at the switch??. did you rewire the whole unit??.
