BLACK STRIPE 1066
Jeff A
02-05-2005 15:22:32
I looked at a 1066 today with the black stripe over the front of the hood. Are these a later model than the ones without the stripe? Are they better than the other ones? Is there anything I need to look out for? We had one without the stripe when I was a kid(the first big tractor I ever drove)and it was a real good tractor.Thanks to all who respond
John Hobby
02-06-2005 10:09:29
 Re: BLACK STRIPE 1066 in reply to Jeff A, 02-05-2005 15:22:32
My 1066 is 1975 and just has turbo on the front nose without any black stripe. Eitherway, it is only a stripe, both nice tractors. Get it and be happy !!!!! !!!!! !!
smoker
02-06-2005 06:43:57
depending on where it fall in line,the early blck stripes were the same as the ones before,then the 86 series parts started to go on them.
the later ones had a different rear and tranny housing,they have the cab mounts on them.
wolfmantractor
02-05-2005 16:56:50
Got to check out the black stripe. Where it goes over the radiator cap (or some such indicator) will tell you if it is a real BS 1066 or just an old 10 with a BS decal added. Better check serial # to see if it is in fact a 1976.
Allan in NE
02-05-2005 15:35:20
Hi Jeff,
The black stripes were the '76 models.
Supposed to be just a touch more ponies; I think about 126 at the PTO & around 108 at the drawbar or something like that.
Allan
JJK
02-05-2005 15:31:30
That was the style of the last 66 series before the 86 series came out. I don't remember for sure but I believe the year of these was 1976. They're not all that different from the early 66's.
Jeff A
02-06-2005 10:15:53
 Re: BLACK STRIPE 1066 in reply to JJK, 02-05-2005 15:31:30
Thanks for the info.Been looking for a early model 1066 and this is the first one I have found of either model.
