Why on earth is it still leaking?
David B
02-05-2005 16:33:11
Hey guys,
The seal was shot for the belt pulley in my B, so I replaced it. Something there is STILL leaking! What would it be, and why?
I need to get this fixed for good. I've sold it, and he'll be wanting to pick it up soon. Thanks, David
Dave BN
02-05-2005 21:12:06
 Re: Why on earth is it still leaking? in reply to David B, 02-05-2005 16:33:11
I agree, it's most likely the spacer(tube). This is designed to be a wear part and is still available thru Case/IH. About $20 as I remember. You can put two seals in there also, which may help. There is an oil return hole in there also, at the bottom and just behind the spacer if I remember right. Having said all of that and done all of that mine still leaks a little. I think it must be leaking between the spacer and the shaft. Dave.
Bob
02-05-2005 20:20:13
Could the oil be leaking between the spacer and the shaft? If it is, clean it up, and seal the spacer to the shaft with silicon.
Jim Becker
02-05-2005 16:57:07
As I recall, that seal runs on a spacer on the shaft. The spacer is held in place by the pulley. Is the spacer in place with no damage on the outside?
CNKS
02-05-2005 18:20:37
 Re: Why on earth is it still leaking? in reply to Jim Becker, 02-05-2005 16:57:07
Same thing happened on my Super A, the spacer is held in place by the v belt pulley for my Woods mower, it does leak a little. On my C I removed the pulley because it cannot be used with my Saginaw 3 point. The spacer is held in place with a plastic tie thing on the shaft -- It leaks less that the Super A. I think that is a rather common problem, unless someone has a sure fix.
