Crankshaft problems
Slappy
02-16-2005 14:45:19
I just got the news from my machine shop - if I'm to reuse the crank for my '44 H, I will need to find 0.040 oversized rod and crank bearings. Anyone know of a source for these?
I know that H cranks are common, but here in Pensacola FL Farmalls are scarce as are tractor salvage yards. So while finding one may not be hard the cost goes up a bumch when you add on shipping. I guess I need to stop carping and see if you all have any suggestions.
Thanks again for your help in advance.
Slappy
02-18-2005 03:14:37
 Re: Crankshaft problems in reply to Slappy, 02-16-2005 14:45:19
Thanks for all the good advice and offers to help guys. I'll explore my options and keep you updated on the outcome.
Norm in Alabama
02-17-2005 13:36:54
Slappy, in the Farmall classifieds ads there is a crank for an H for sale in MO. He wants $125 shipped if you decide to replace yours. I am north of Huntsville, AL and if I can help in any wy we have several junk yards within 50 miles. Be glad to check on something for you if in need. Address is uncovered.
Tailhunter
02-16-2005 19:43:44
third party image
There is one for sale in the photo ad section. Under Parts (#94498)
Rob
Cowgill, Mo
660-255-4551
One heck of a good crank.$150
El Toro
02-16-2005 17:03:51
Give Federal Mogul a call at 1-800-325-8886. They can tell you where they're available in your area. Hal
MagMan
02-16-2005 16:52:38
Hi there Slappy, My H has been run since about 1970 with a 40 thousands under crank with not even a problem And she is plum worn out now but the crank not to bad yet. The shop should be able to order them Federal mogual JON
farmalljim10
02-16-2005 15:54:59
A guy has one for sale on the classified ads for sale right for 125.00 But.40 should be ok for a farmall they had really big journals any how..At least the M and Hs.
John M
02-16-2005 15:47:53
Find a Tisco dealer,they can order them.
Michael Soldan
02-16-2005 15:39:47
Slappy, something Kevin said rings a bell. At the auto shop I used to work at we had two major suppliers and Ideal Supply which was the NAPA franchise had a machine shop that could build up a crank, turn it and send it back like new, it wasn't unreasonable...as far as a used crank, Steve at Ontario Used Tractor Parts would have good ones and he would ship...Londesborough Ontario to Florida....Hmmm...don't know what the cost would be, he'd use UPS likely...anyway , good luck...Mike in Exeter Ontario
Tailhunter
02-16-2005 15:34:25
My supplier has 2,10 and 20 under bearings. I've seen 30's...do they even make 40's....Maybe time for a new used crank...call mike...steel wheel ranch.
KevinH
02-16-2005 15:11:38
About 4 years ago, I had NAPA send my F-12 crank off to be what they called"flame-built". I got back a crank that was standard and I think it was less than $175 and there was no shipping "cause it went on their truck. Just a thought, Kevin
Allan in NE
02-16-2005 14:51:15
Ouch,
Wow, that's gettin' pretty thin for a crank; I get nervous at .010".
Have you thought about Mike at www.steelwheelranch.com ? He can shoot one to ya, I'll bet. An H crank isn't that heavy, so the freight shouldn't be that high, I wouldn't think.
Allan
justin w
02-16-2005 15:28:05
 Re: Crankshaft problems in reply to Allan in NE, 02-16-2005 14:51:15
Nervous at 0.010????? That is the first grind..... ..... . IH originally only offered STD, 0.002, 0.030, & 0.032. 0.040 bearings were offered by some aftermarket suppliers, and 0.060 (semifinished) were offered also. The 0.060s would need to be sized to the crank by the machine shop. The bearings you are looking for are out there, you just need to find them....
Andy Martin
02-16-2005 15:01:35
I thought 0.040 were available for M's and H's. Does the machine shop not have a source?
Still plenty of crank.
