Hydra Touch Seals
PAULIH300
02-18-2005 12:37:03
Seeing as how CASE/IH no longer supports the rubber sealing rings associated with the Hydra Touch valves,has anyone changed all of theirs and recorded somewhere the sizing of them?
Also the sealing rings for the hydraulic piping that runs from the pump to the reservior (large and small rings).
Tractor is a 300U.
superdave57
02-18-2005 17:11:50
 Re: Hydra Touch Seals in reply to PAULIH300, 02-18-2005 12:37:03
The seals are standard O rings, if you take them to a hydraulic supply store, they should be able to help you.
CNKS
02-18-2005 12:43:57
You sure your dealer can't get them -- do you have a parts book? Some don't like to look up numbers, you give him the number, they might well be available. I've found very few seals IH can't get, hydraulic or otherwise, on tractors older than yours. Unless they are some oddball size, any good bearing/seal place should have them;also, it is likely that the IH part number can be crossed to theirs.
PAULIH300
02-18-2005 12:47:44
 Re: Hydra Touch Seals in reply to CNKS, 02-18-2005 12:43:57
350667r1
352221r1
350818r1 All NLA
CNKS
02-18-2005 13:13:00
 Re: Hydra Touch Seals in reply to PAULIH300, 02-18-2005 12:47:44
Try this link, and click on the links -- apparantly made by Navistar-International -- just enter your number in the search box.
