b farmall water pump
JOEL KIMMINS
02-23-2005 14:53:16
IF YOU PUT A WATER PUMP ON A B THAT DID'NT COME WITH ONE. WHAT AT ALL DO YOU HAVE TO DO TO MAKE THE GENERATOR TIGHTENING BRACKET, THE TEMP GAUGE AND SO ON WORK .I PUT ONE ON MY B AND THE FAN BLADES HIT THE WATER PUMP SHAFT.THE TEMP SENSOR IS'NT LONG ENOUGH. HELP PLEASE.
Paul in Mich
02-24-2005 06:38:03
 Re: b farmall water pump in reply to JOEL KIMMINS, 02-23-2005 14:53:16
Why do you feel you need a water pump? They did not require one as they came from the factory. If you are overheating, probably a good engine flush will be more effective than an added on water pump.
dg587
02-24-2005 20:09:27
 Re: b farmall water pump in reply to Paul in Mich, 02-24-2005 06:38:03
typical mich. answer
