Order Farmall Cub Parts Online
Cub Hydralic pump ??
PLOWPUSHER
03-06-2005 13:33:09
Did the cub hydralic pumps have a tendency to leak hydralic oil into the engine, like super A and C's did? HOW hard is it to change the seal if I had to ? Plowpusher
Rudi
03-07-2005 11:55:29
 Re: Cub Hydralic pump ?? in reply to PLOWPUSHER, 03-06-2005 13:33:09
third party image
George is right on as usual. If you go to the Cub Manual Server, you will find under the Blue Ribbon Service Manuals, the 1024- Touch Control Manual. Also, under Cub Maintenance is the Touch Control Maintenance Manual (slightly different). In the Parts Manual section you should be able to find the part numbers you neeed. Remember to ensure you have the right part number from your reservoir.
George Willer
03-06-2005 14:15:26
Yes, they also have that tendency. The hardest part of the job is draining the system. That's easy too if you don't care if you make a mess. There are two different pumps. One that uses a regular seal and the later one that seals with an O-ring.
