What size rotary mower for a Farmall M?
Nathan in Texas
03-08-2005 15:31:53
Okay, I just bought a nice old M and am ready to buy a rotary mower for it.
Talking with people it sounds like a 5' is just too narrow and will not work well since the M's tires are wider. Most people say I need a 6'. I was looking at 7' and 8' models but they get REALLY expensive and heavy as well. Not sure how well the M would run something that big and heavy.
I have a thread going in implement alley right now on what brand to buy and you are welcome to help me with that decision as well, but basically I need to know what size to buy as well.
So what size should I get?
If you want to comment here on what brand this is my current choices locally and my ranking on my preference right now:
1 - 6' Cimarron - $850 (in stock)
2 - 6' King Kutter - $900 (in stock)
3 - 6' Howse - $800 (on order)
4 - 6' Armstrong - $800 (on order)
5 - 6' Rhino - $1,195 (in stock)
6 - 6' Bush Hog - Squealer - $1,450 (in stock)
Thanks, Nathan
Nathan in Texas
03-12-2005 18:31:32
 Re: What size rotary mower for a Farmall M? in reply to Nathan in Texas, 03-08-2005 15:31:53
third party image
Well I ended up getting a Cimarron 6' economy mower for $850 from the local Case Tractor dealer. Seemed like a pretty good deal, the salesman I had talked to was out when I went to buy it and they had to check with him to make sure that was the price he had agreed too.
I mowed 12 acres this afternoon and was pretty happy with how it went. Mowed down some big dead tumbleweeds and would do pretty well in 4th gear on the regular stuff. Was still pretty slow though, took me about 6 hours to get the 12 acres done. I think I can go a little faster now that I have it figured out but I doubt I'll be doing much more than 3 acres per hour with this setup. Had 15 gallons of gas and didn't run out so that was good I thought.
Took a few pics of the mower hooked up. The dogs figured out to stay a bit farther away once the mower was running! ;-)
Nathan in Texas
03-12-2005 18:33:32
 Re: What size rotary mower for a Farmall M? in reply to Nathan in Texas, 03-12-2005 18:31:32
third party image
Here is a closer pic:
Nathan in Texas
03-12-2005 18:36:21
 Re: What size rotary mower for a Farmall M? in reply to Nathan in Texas, 03-12-2005 18:33:32
third party image
And one from behind:
With the tires all the way in the mower is actually almost as wide as the tires.
qusetioned
03-08-2005 19:27:29
Nathan,I have a side questioned maybe you can help me with.I have a guy selling a M for a 1000.oo dollars the motor needs work possible a piston arm went bad he is not sure.It has a front loader and a box scraper with it, it look to be in good shape except for the motor not working is this a good price or is it to high? The old guy won"t budge on the price. Thanks for your time Dan
Nathan in Texas
03-08-2005 20:58:12
 Re: What size rotary mower for a Farmall M? in reply to qusetioned, 03-08-2005 19:27:29
I am by no means the person to answer your question as I haven't had my M a week yet!
But I'll try.
I bought mine for $2,500. It included the 3 pt hitch, 7' straight blade and post hole digger. I figure I paid $2,000 for the tractor and $500 for the blade and post hole digger. The tractor seems to be in perfect working order with good tires and looks clean, hydraulics work good, no smoke, etc....
With that said, a box blade is worth $300 or so in pretty good shape and a front end loader can be worth up to $1,000 installed and working.
The $1,000 price tag would be worth it for the scraper and loader IMO and you could part the M out if it is going to end up costing you too much to get it running.
Now, if you are just wanting a tractor to buy and use like I was, this wouldn't be a good deal probably. All of those options are going to take time and effort on your part but the price doesn't sound that far off to me.
(But I really don't know what I'm talking about!)
FWIW, Nathan
qusetioned
03-10-2005 20:55:35
 Re: What size rotary mower for a Farmall M? in reply to Nathan in Texas, 03-08-2005 20:58:12
Nathan thanks for the help.You sound like you know alot to me.Dan
GNB
03-08-2005 17:07:56
Why not look for a good used bush hog to go with the M? I have a M and it would be hard for me to pay as much for a bush hog as I did my tractor! Just a thought. Good luck with the M. They are fine tractors.
GNB
wolfmantractor
03-08-2005 16:55:16
Not all types or brands of rotary mower require the same power. We have a 7-ft pull type A-C that takes less power to run than either of our two 6-ft 3-pt ones(one a genuine Bush Hog brand; the other an International- not IH). The Bush Hog is for sale for $500 but it won't help you since it is in s.w. Pa. ! Seems the one big 7-ft blade once reved up cuts better & with a lot less power needed; but you better stand back.
PeteNY
03-08-2005 16:51:05
Nate, Your M WOULD certainly handle a 7'er, but you are right they get REAL expensive REAL quick once ya get over 6'. The dealer I have worked for for quite a while sells Howse as a budget alternative to our Bush Hog line...what most guys cut, the Howse is fine, but that Squealer is sweet! Work the dealer a litlle, ya should get it $150 -@200 cheaper. Pete
John M
03-08-2005 16:50:06
I have the three point BUSH HOG on my M right now,had it for about 3 years or so and has never given me a days trouble.I had the King Cutter before that but something about it just dint suit me.You could really get by with a 5 ft on a M since you have a three pt,and I have seen a couple folks around here pull a 8 ft with their Ms but were going in like 1st or 2nd with it.
john in ohio
03-08-2005 15:40:29
i pull a 6' king kutter with my m and it does fine.
Nathan in Texas
03-08-2005 16:31:38
 Re: What size rotary mower for a Farmall M? in reply to john in ohio, 03-08-2005 15:40:29
Just to clarify, I do have a 3 pt setup on the M and know I need to get an overrun clutch for whatever mower I end up with.
Also the King Kutter is at a farm supply store (Gebo's) that probably won't be much in the service category if something goes wrong, and the Cimarron is at a tractor place that will be able to service the Cimarron and carry parts if something does go wrong.
Thanks for any input.
Nathan
