What Farmall Used the Cable shut off For H4 Mag
MagMan
03-10-2005 10:52:48
Hi Guys does anyone know what Farmalls and what years used the cable shut off to the switch on the side of the H4 magneto? Or Is anyone rebuilding such a beast? Was it H and M 1939 or were there more models and years? JON
Jim Becker
03-10-2005 17:59:09
 Re: What Farmall Used the Cable shut off For H4 M in reply to MagMan, 03-10-2005 10:52:48
Yeah, what Paul said. The serial break for the change should be in the parts books. For the A and B it was 35,260, which was late '40.
Red Dave
03-11-2005 04:39:09
 Re: What Farmall Used the Cable shut off For H4 M in reply to Jim Becker, 03-10-2005 17:59:09
That would make sense, my '40 B has the button, not the cable and it's in the 38,000 serial number range. No evidence on the tractor that it ever had a cable either.
Steve Metz
03-10-2005 15:47:43
My 39 M is as you say.
John M
03-10-2005 12:23:06
it was to my understanding that that was considered an accesory on early letter series before the buttons.before that it was just a peice of bent metal that you pushed on the mag and was connected where the switch wire would connect and it ground the mag when pushed.
Chad from MI
03-10-2005 11:56:44
our 1940 Farmall A has the cable kill on it! It also has no other electrical on it.
chad
Paul in Mich
03-10-2005 11:47:12
The cable kill switch was on all the new letter series tractors of 1939 using the H-4 magneto, and was continued on the 1940 models as well. To the best of my knowledge, the push button kill switch appeared on the 1941 models. There were, however, still some F and W series still in production in 1939 that used the F-4 not the H-4 mag.
