WHAT --- PTO implements for ?
Jonn
03-14-2005 08:31:50
Have a couple of Super As. Wondering what kind of Implements were powered by the PTO. Seems like the high angle of the unit would not let an implement such as a 5 ft mower to be used. So just what was the PTO used to power? Can they use implements such as you would use with say a Ford 8N? Thanks for any info.
big fred
03-14-2005 10:48:10
 Re: WHAT --- PTO implements for ? in reply to Jonn, 03-14-2005 08:31:50
Local truck farm used their Super A and Super AV and 140 for cultivating, spraying, and pulling wagons in the field during harvest. The sprayer ran off the PTO
scotty
03-14-2005 09:28:50
Hi Jonn, The sicklebar mower was very popular to have on those tractors, I have one for mine and it works great. Also the rear mounted cordwood saw attachment that runs off of the belt pulley was pretty popular also. I think the tractor is more noted for its cultivating capabilities than its PTO work. Im sure there were others, that the other guys will add in.
scotty
Andrew Z
03-14-2005 13:47:52
 Re: WHAT --- PTO implements for ? in reply to scotty, 03-14-2005 09:28:50
I used my Farmall A last summer to ted hay. The tedder was a New Idea (2 row) The guys that I was doing hay with were shoocked that the little A had the power to turn a two row tedder, also tedding was done in third gear. All kinds of power!! Andrew
