Does plow mount on top or bottom of draw bar on SA
scott#2
03-16-2005 04:16:03
Going to try to get it mounted today.
Thanks,
scott
Haas
03-16-2005 07:48:27
 Re: Does plow mount on top or bottom of draw bar o in reply to scott#2, 03-16-2005 04:16:03
I always mounted mine on the bottom of the drawbar. Never had a plow manual but the mounting plates were worn on the plow in a way that indicated it was always mounted on the bottom. Also, for the wheel settings I used, had to be bolted to the outer most holes on the drawbar. only worked in those holes on the bottom, as springs or something interfered when mounting to the top.
Doug Kieta
03-16-2005 06:50:30
I've always mounted mine on the top of the drawbar. Works well and easier to lift an align the holes.
Thomas Brown
03-16-2005 05:44:47
It should be on the bottom.
Jim Becker
03-16-2005 05:27:20
The manual shows it on the bottom. I'm not sure it makes any real difference.
Maple Springs
03-16-2005 05:17:13
The old Yankee who bought my '48 SA new always mounted it on top of the drawbar. This seems to make sense, as having it rest there might give you a few seconds to notice -- before the beam fell and dug into the ground -- if the bolt ever loosened.
scotty
03-16-2005 04:47:18
Hey Scott, Darned if I know, I never plowed with mine but sure would like a good picture of yours when you get her all hooked up! Thanks.
scotyty
