IH 656
Tip
03-16-2005 05:23:01
I got my 656D running and am now trying to track down my TA issue. First, I am not 100% the tractor has a TA - the lever on the left of the control console looks like a TA control, but is marked high/low/neutral down toward the base? Is this the way it came from the factory?
I have a factory service manual and the TA lever adjustment is out for sure - I am going to adjust it later. I also
wanted to pull the inspection plate to take a look and see if I have a TA and if so, to measure the clutch release clearance. Sorry if these questions seem silly - the tractor is new to me. Can I remove one of the bottom inspection covers and take a look or do I need to remove the battery box etc. to take a look?
Thanks again.
Tip
K.B.-826
03-16-2005 16:10:12
 Re: IH 656 in reply to Tip, 03-16-2005 05:23:01
Is the tractor a gear drive or a Hydro? Hydro's will have a high/neutral/low lever on the left and the forward/reverse/speed control lever on the right. Gear drives will have the TA on the left and 5 forward/ 1 reverse on the right.
Tip
03-16-2005 16:28:33
 Re: IH 656 in reply to K.B.-826, 03-16-2005 16:10:12
Sorry about that - an International 656 D with regular gear transmission - no hydrostatic. Shift on the right and a control on the left that is either high/low/neutral or a TA that doesn't work. FYI, the linkage on the left shift looks like the TA shift in the service manual - they don't have a picture of the hi/low so I don't know what I am looking for.
Thanks, Tip
Harold H
03-16-2005 09:48:29
I believe International 656 and 2656 were available with high-low range, however, this option was not available on Farmall 656 which was available with or without TA or with hydrostatic drive.
Harold H
Allan in NE
03-16-2005 06:26:03
Tip,
You didn't say if your tractor is an International or a Farmall.
Local red shop was telling me the other day that he had just bought one that was equipped with some kind of a Hi/Lo box and it was not a T/A at all.
Dunno,
Allan
third party image
Tip
03-16-2005 07:57:46
 Re: IH 656 in reply to Allan in NE, 03-16-2005 06:26:03
Thanks Alan - it is an International - believe '68. I am guessing that the raised cover in your picture is the TA access cover. I don't believe mine looks like that - need to go and take a look.
From the service manual, IH made the tractor with a hi/lo tranny. I may have that transmission in the tractor. I will post more when I know more.
Tip
