Source for a re-maned engine needed
Paul in WI
03-18-2005 16:49:04
need a rebuilt short block(bad crank)
El Toro
03-19-2005 09:05:53
 Re: Source for a re-maned engine needed in reply to Paul in WI, 03-18-2005 16:49:04
You can locate a Perkins dealer near you by going
to Link What's wrong with the current engine? Hal
Paul in WI
03-19-2005 10:41:29
 Re: Source for a re-maned engine needed in reply to El Toro, 03-19-2005 09:05:53
The engine I have needs a complete re-build and the crank has worn splines on the front where the pully/dampner goes.
I have tried that perkins site and didn't find it very helpful.
El Toro
03-19-2005 11:45:17
 Re: Source for a re-maned engine needed in reply to Paul in WI, 03-19-2005 10:41:29
Try Foley Engines at 1-800-23-foley and their email is info@foleyengines.com. The sell Perkin engines. Hal
El Toro
03-19-2005 11:40:18
Did you have a machine shop to look at that
loose spline to see if anything could be done to
it? Some other tractors used Perkins engines, I just can not remember which tractors. Someone
that posts on here may know. Hal
Paul in WI
03-19-2005 07:33:27
sorry guys,its a 1850 Oliver w/354 perkins
El Toro
03-19-2005 08:53:52
 Re: Source for a re-maned engine needed in reply to Paul in WI, 03-19-2005 07:33:27
Try Capitol City Oliver Co. at 1-800-252-3049 or Mills Motor Parts at 1-800-624-7999. Hal
Harold H
03-18-2005 17:52:15
To fit what tractor?
Harold H
