Dixieland fess up
fredmich
03-23-2005 12:17:53
Come on Dixieland, tell us what you have found on your starter problem (stumped) and blowing your breather cap off! Inquiring minds want to know!
Dixieland
03-23-2005 15:22:13
 Re: Dixieland fess up in reply to fredmich, 03-23-2005 12:17:53
Hi Fred...Thanks for the curiosity...Gene was right on the connections I think because I changed them back to negative ground and it worked good too. Sometimes you think you have a good connection because you tried to make sure but I guess that's what I get fer thinking. El Toro suggested that I connect with a positive ground and that must have been when it got a good connection. You never know how you look till you get your picture took!!!Shame on me! Allen in Nebraska said he had a similar incident about the oil cap with fuel in the oil so I drained it and replaced the oil. Has'nt done it anymore. Still have a little bit of a skip now and then even after I reset the valves to .014" as suggested by CNKS but it did improve it somewhat. It is amazing that someone always has an anwser and it is a great help and saves a lot of time. Don't have to scratch your head as much....Thanks...Dixieland
fredmich
03-24-2005 10:06:07
 Re: Dixieland fess up in reply to Dixieland, 03-23-2005 15:22:13
Thanks for the update Dixieland, there is a wealth of information out there and there is nothing like experience. Fred
gene b
03-23-2005 15:01:38
They finally got the connections tight and now it starts.
Dixieland
03-23-2005 15:23:12
 Re: Dixieland fess up in reply to gene b, 03-23-2005 15:01:38
Thanks Gene
