Super A final drive
PM
03-25-2005 13:16:25
From the popping sound comming from the final drive on my super A, I think the bearing/bearings are bad, ordered rear axle inner/outer& differential shaft bearings as well as seals. I have a cub lowboy with a fast hitch & plan on constructing a jig assembly to lift & ease out the final drive. Is this a straight forward job? any tips or suggestions before starting.
Thanks in advance,
Paul
PM
03-28-2005 05:45:11
 Re: Super A final drive in reply to PM, 03-25-2005 13:16:25
Jim & Haas, thanks for the suggestions I went thru and tightened the bolts on the rims & hubs the popping sound has subsided for now, will monitor.
Paul,
Haas
03-26-2005 14:34:28
Have you checked the bolts that fasten the rim to the hub. If they are loose, it will cause a popping sound.
Jim Becker
03-25-2005 21:26:39
I suggest you try tightening the lug bolts before you take it apart. It might save you a lot of work.
