pully
hw1227
04-18-2005 15:03:42
onyone have any easy way to pull the crank pully off of a 300. got no room for a puller dont want to take radiator or front end apart. just want to chang a belt, HELP!
captaink
04-18-2005 16:45:43
 Re: pully in reply to hw1227, 04-18-2005 15:03:42
This is going to be quick.
To change the fan belt, the top pulley is split with the front half threaded to move in and out. There is a set screw in the hub that “locks” the pulley half in place. This is how the belt is tensioned. If you turn the front half counter clockwise (as viewed from the radiator) the belt will loosen and you will be able to remove it.
Be careful as this is cast iron and will break easily. I'd oil it up good and let it set overnight at least before I'd go to work on it.
Good luck :>)
Joe Kimbriel
04-18-2005 15:32:09
Why do you need to pull the crank pully to change a belt?
