Getting hood off a 400
supergrumpy
04-19-2005 12:55:53
helping a neighbor fix his exhaust leak, hood is in 3 sections with air cleaner tube with big cyclone top sticking up thru piece I need to remove
got the exhaust side cowl loose but cannot figure out how to get air cleaner cyclone tube top off without removing huge amount of air cleaner and plumbing
November Indigo
04-19-2005 13:20:13
 Re: Getting hood off a 400 in reply to supergrumpy, 04-19-2005 12:55:53
The cyclone cap should come right off. It's just shoved on the air cleaner inlet tube like the stock "mushroom cap."
supergrumpy
04-20-2005 07:43:11
 Re: Getting hood off a 400 in reply to November Indigo , 04-19-2005 13:20:13
sure enuf
that rascal was glued on tight by a lot of years but finally wiggled a bit, climbed up top and finally got it off
exhaust manifold is a lot easier to work on now
thank you.
