Steering U-joint
RustyFarmall
04-27-2005 14:13:24
Got a question. The steering u-joint on my 1940 H is totally worn out, it is the old style, so, according to the parts man at case-ih, a replacement cross is not available. I have a complete u-joint that I picked up at a swap meet, and it was removed from an H. The problem I have is that the replacement does not have a slot for a key, but instead would require that I drill a 5/16 hole through both of the steering shafts, Do I want to use roll pins or bolts to secure the u-joint to the shafts? If bolts, what grade?
Farm w/Junk
04-28-2005 11:41:30
 Re: Steering U-joint in reply to RustyFarmall, 04-27-2005 14:13:24
One word of advice. Use caution if you plan to use a bolt. Friend was driving his H in 5th gear down the road and the nut came loose bolt fell out and wheel went sideways. Luckily there was no ditch and the tractor didnt flip but it was one scary ride for him. Double nut or lock it on good. Take care and be careful.
Matt
P Backus
04-28-2005 07:13:11
Another option would be to take the new joint to a machine shop and they can run a keyway broach through it to create a keyway of the appropriate size. It's not a terribly complicated process, so it shouldn't cost big $.
Paul
Ed Topel
04-27-2005 20:46:23
I got the correct cross from Joes Farmall a couple of years ago. If you call be sure to tell him it's the old style and you just need the cross, not he whole joint.
Mike ISW
04-27-2005 14:49:50
Seems to me i got a u-joint from my dealer, but i can"t find invoice with part number. Grade 5 should be sufficient to secure that yoke. Use NF threads and a lock nut torqued to specs. My opinion,Mike
RustyFarmall
04-27-2005 14:53:39
 Re: Steering U-joint in reply to Mike ISW, 04-27-2005 14:49:50
Thank you, sounds like that might work.
r4etired
04-27-2005 18:18:12
 Re: Steering U-joint in reply to RustyFarmall, 04-27-2005 14:53:39
I have used several aftermarket U joints, I use 5/16 roll pins with a smaller size pounded inside the 5/16. personally trust them more than bolts. They fit tighter than any bolt will so you get the original play that starts the wear
