Order Farmall Cub Parts Online
Cub spitting through carb(help)
GNB
04-27-2005 19:23:15
I finally got a good spark after new points and coil. I tried cranking it and it is spitting through the carb but no go. The carb has not been rebuilt yet. I guess it was wishful thinking that it would fire up. Could the problem be simply in the carb? It never tried to start just spitting every now and then. Thanks in advance.
GNB
EricB
04-29-2005 04:41:56
 Re: Cub spitting through carb(help) in reply to GNB, 04-27-2005 19:23:15
Check your point gap. Sometimes thoses suckers slip when you do the final tightening.
MagMan
04-28-2005 03:17:18
It sounds like you may have installed the Dist or Mag 180 or more or less off timing.try switching the cap wire 180 and try it again. MagMan
gene (Missouri)
04-27-2005 21:57:07
Going to need a little more information. Some background on the engine.
1) Was the motor's condtion before you changed the points.
2) Are the valves working (stuck).
Eugene
