F-12 to F-14 oil pump swap
andy b.
04-30-2005 20:56:24
the pick-up on the oil pump on my F-14 is broken off at the bottom of the pump (where the tube connects to the plate on the bottom of the pump). i have a F-12 parts tractor (serial # 93xxx or so) and the pump is good on that one. the pump bodies look the same, but the pick-up on the F-12 pump is connected right to the bottom of the pump and is about a 8" diameter disc with a screen on one side. is there any reason i can't just use this pump on the F-14?
thanks,
andy b.
John M
05-01-2005 06:12:15
 Re: F-12 to F-14 oil pump swap in reply to andy b., 04-30-2005 20:56:24
Two pumps are being shown,(that i can find)in the parts book,one is 24553D for FS 600-608,FS 3035-41590 and 4834 DX for 41591 and up so yes,it should work.
andy b.
05-01-2005 18:33:48
 Re: F-12 to F-14 oil pump swap in reply to John M, 05-01-2005 06:12:15
John,
thanks for the reply. yes, that casting number is on both pumps. i was just wondering if there was some horrible reason not to use the F-12 pump with the big screen on the bottom.
i installed the pump and the big pick-up seems to fit okay, so i guess i'll go with it.
andy b.
