966 injection pump
hossw
05-02-2005 20:05:20
Does anyone know how to turn up the pump on a 966 with an american bosch pump? It"s different than a roosamaster, so I"m not sure where the screw is. Thanks.
gramps
05-03-2005 18:36:52
 Re: 966 injection pump in reply to hossw, 05-02-2005 20:05:20
yes take off the cover with the four screws and then you will see a screw with a lock nut loosen the nut and back out the screw about 3 turns and you will really notice a difference. It is real noticable if you had a turbo. Make sure to tighten everything back up just like it was.
hoss w
05-03-2005 19:48:44
 Re: 966 injection pump in reply to gramps, 05-03-2005 18:36:52
gramps,
I backed it out 3 turns. I already put a turbo on it, wow, what a difference!!! I want to pull farm stock this summer, how far do I dare back it out without burning it up??? I know there are risks, but no more than when I get close to any tractor with tools in my hand!! Thanks
Hoss w
w gatewood
05-02-2005 20:25:05
its under the cover at the rear of the pump with the 4 1/4 inch bolts. you can set up the torque rise and also the droop screw and you can put a little fule to it if you need to do so.
