Correct Carburetor for Super C
Dave from Texas
05-04-2005 07:04:01
I am starting to work on a 1951 Super C (Serial # 122,445). What is the correct carburetor? I see on Ebay there are both Carter and Zenith. The adds say both will work. Will I experience a reduced HP if I use the wrong one?
Dave_Id
05-04-2005 11:24:11
 Re: Correct Carburetor for Super C in reply to Dave from Texas, 05-04-2005 07:04:01
The Zenith has an extra adjustment than the Carter. I never could get that Carter set properly. It always ran too rich.
Peabody
05-05-2005 05:28:46
 Re: Correct Carburetor for Super C in reply to Dave_Id, 05-04-2005 11:24:11
I've never had a bit of trouble with my Carter carb.
RustyFarmall
05-04-2005 07:50:09
If you don't mind me asking, what is wrong with the carburetor that came on the tractor?
Dave from Texas
05-04-2005 08:04:29
 Re: Correct Carburetor for Super C in reply to RustyFarmall, 05-04-2005 07:50:09
It did not have one. It had been removed years before I purchased it.
Glen E.
05-04-2005 07:21:01
I believe either one is right. Super Cs came out with two different carburetors. If you have an owner's manual I think it will show adjustment procedures for both. There should not be any reduction in HP.
Joe Kimbriel
05-05-2005 11:10:44
 Re: Correct Carburetor for Super C in reply to Glen E., 05-04-2005 07:21:01
These are the numbers that I found.
1951 4 123 Super C Carter 771 A 354892R92 1951 4 123 Super C Zenith 11115 355485R91
Joe
