2404 international
bigearl
05-05-2005 10:08:38
I need some info on this tractor. hp, if a 3 pt hitch cam be gotten for it and just general info. I bought one yesterday.
Harold H
05-05-2005 19:18:10
 Re: 2404 international in reply to bigearl, 05-05-2005 10:08:38
The International 2404 is the industrial version of the International 404. It was built 1961-1968. The serial numbers are in the same numbers with the I-404 (not F-404). It is about 37 pto hp and 34 db hp. If your tractor is equipped with a rockshaft it can be fitted with a three point from a I-404. If it does not have a rockshaft it would be a major operation as you will have to change the transmission top and some internal parts with the complete setup from a donor I-404. Most all parts from the I-404 are the same as the I-2404. The main differences were the front axle and grille, color, and different tires and different options.
Harold H
