Broken Fast Hitch
Joe
05-05-2005 17:35:11
Was out plowing this afternoon with a two bottom plow on my 53 Super C.
The tractor was doing a great job plowing ,I was really having a good time when all of a sudden I got bogged down ,no problem just feather up the plow a little bit and keep goin right ! Wrong I look back and down and the plow is cocked at a wierd angle %%#$@%%@
I turn the tractor off and climb down for a look and see that one of the Fast Hitch arm's is snaped off right at the bearing /mounting plate
Looks like I'm in for a little down time .Any body know if these parts are available ? and where ? Any idea how much they would cost ?
Thanks Tom
Nat
05-06-2005 08:33:57
 Re: Broken Fast Hitch in reply to Joe, 05-05-2005 17:35:11
Aw heck, a little grinder work, and some time with the ol' Lincoln buzz-box, and you'll be back up and running for peanuts...
RickB
05-06-2005 03:21:06
email me. I probably have what you need. I'm in NY
Joe
05-07-2005 12:14:35
 Re: Broken Fast Hitch in reply to RickB, 05-06-2005 03:21:06
Hey Rick I emailed you but not sure if it went through or not ???
farmallhal
05-05-2005 18:31:51
Send an email to David at dagect@dtccom.net as he ran a classified ad last week with some fast hitch parts for sale for SC or 200 model tractors. I believe he might have the parts you need.
farmallhal
05-06-2005 05:02:03
 Re: Broken Fast Hitch in reply to farmallhal, 05-05-2005 18:31:51
Joe, looks like I had a little typo, try this one - dagecr@dtccom.net - this one should work. Good luck.
Joe
05-06-2005 01:38:56
Hal,
I tryed to send david a email but it bounced back ;wasn't able to deliver your message any idea how to contact David
farmallhal
05-06-2005 05:54:17
 Re: Broken Fast Hitch in reply to Joe, 05-06-2005 01:38:56
Joe, try David at dagecr@dtccom.net - sorry about the typo. Hal
El Toro
05-05-2005 18:19:44
Any chance that the broken part could be welded?
This may be easier to fix than finding a replacement part quickly. Hal
PS: You can place an ad on BESTFARMBUYS.COM to see if someone has the part you need for free.
joe
05-05-2005 18:27:50
 Re: Broken Fast Hitch in reply to El Toro, 05-05-2005 18:19:44
I don't think it can be welded ...But I am going to check into that first .
Thanks for the tip on Bestfarmbuys ..I'll give them a try
Joe
