international 186 hydro, no reverse
David Truesdale
05-08-2005 10:28:32
I have a 186 hydro and no matter where I move the lever for forward or reverse it still goes forward. Iwould like to know if this might be in the trans. or in one of the valves. Thank you for any info. Would like to thank the tractor vet for the info on the 706. David
David Saville
05-08-2005 21:33:41
 Re: international 186 hydro, no reverse in reply to David Truesdaled, 05-08-2005 10:28:32
I had that problem with mine once. It is not really serious but you have to go inside the transmission. No split is necessary. It is long enough ago that I hesitate to add further info without fear of misdirecting you. If you still have a good IH hydro mechanic around he will be able to diagnos it for you. If you can't find better help phone me 306 295 4122.
Nebraska Cowman
05-08-2005 11:02:43
sounds more like the linkage might be unhooked somewhere?
