pto wont clutch out
hank n' tx
05-10-2005 17:28:30
i just bought a international 340 deiseland noticed that the pto wont disengage. is this a difficult fix? what will i need to do to fix it? need some idea before i tear into her. thanks hank
Janicholson
05-11-2005 09:35:25
 Re: pto wont clutch out in reply to hank n' tx, 05-10-2005 17:28:30
A independent PTO that has been left on for years and not used may be stuck on (seen it to be the case). Do the band adjustment as per prior post. With tractor shut off, PTO lever positioned between on and off, try to turn the shaft. at some lever position between on and off the shaft should be free. If it does not spin freely, I believe additional pressure can be applied (using a splined coupler to protect the splines) to get it loose ( not more than 150 ft/lbs). if still stuck on, taking it apart may be the only choice.
good luck JimN
Ernie Bob
05-10-2005 18:55:15
I believe the 340 has live PTO and is controled by a seperate lever to enguage and disenguage the PTO. If it continues spinning with the lever in the disenguaged position then I would try adjusting the LPTO bands. This is covered in the manual, it's not dificult to do. I would try this before tearing into it.
Good Luck!
Ernie Bob
Allan in NE
05-10-2005 17:48:16
Hi Hank,
Dunno, but they way you worded the post, it sounds like you are under the impression that the clutch controls the PTO? It doesn't.
If this isn't the way ya meant it, I'll get outta your hair. :>(
Allan
hank n' tx
05-10-2005 19:44:57
 Re: pto wont clutch out in reply to Allan in NE, 05-10-2005 17:48:16
i just worded that away. the pto stays running all of the time. i cant get it to disengage. i move the lever all the way and she wont disengage. thanks hank
