3 point hitch for Super C
Wes A.
05-11-2005 15:36:37
Just purchased a restored 1951 -1952 Farmall Super C. Is there a 3 point hitch available to buy. Appreciate all e-mails.
CNKS
05-11-2005 17:48:35
 Re: 3 point hitch for Super C in reply to Wes A., 05-11-2005 15:36:37
The best hitch is made by Saginaw County Tractor, www.saginawcountytractor.com -- their web site will not list one for a C, but call, they have it. It has a hydraulic cylinder, the others operate off the rockshaft in the front, the rod from the rockshaft to the lift arm is in the way. If your C has a hydraulic remote attachment (for trailing implements), the cylinder will work off that. If not Saginaw sells a spool valve you can mount on the light bar, and an adapter that fits between the reservoir and the hydraulic pipes. A little clutzy because of all the hoses that attach to the spool valve, but it works perfectly -- I have one on my C.
Dixieland
05-11-2005 16:00:58
Hi Wes...there are some aftermarket hitches available for your super c but be selective. With some you have to be an acrobat to mount and dis-mount your tractor.
tyler mostia
05-12-2005 17:10:17
 Re: 3 point hitch for Super C in reply to Dixieland, 05-11-2005 16:00:58
if your super c has a fasthitch on it which is 2 slots on the back where you can put various implements and a drawbar in it many companies make a 3pt conversion to fit in the fasthitch they even have them on this site
