Order Farmall Cub Parts Online
Cub (Ridge reamer wont fit)
GNB
05-14-2005 06:41:47
I can not find a ridge reamer that will fit in cylinder of the cub engine. I am going to take the crankshaft out. Question is will the pistons slide out the bottom after crankshaft is out without needing a reamer? Looks like that may work. I have got to carry the block to a machine shop anyway to be fixed and cleaned. Thanks
GNB
John M
05-14-2005 10:46:23
 Re: Cub (Ridge reamer wont fit) in reply to GNB, 05-14-2005 06:41:47
I had to use one made for little lawn mower engines,but yes they will come out the bottom once the crank is out.
El Toro
05-14-2005 09:01:15
I think the pistons can be removed from the bottom of the block after you remove the crankshaft. Give it a try anyway and if there's a problem, the machine shop can remove the ridge and then remove the pistons. If it is worn beyond the specs the block may need to be bored oversize. Hal
