Order Farmall Cub Parts Online
Fuel Problems for '53 Cub
Molly
05-16-2005 18:59:41
I'm having a problem with the fuel flow for my cub. The problem started after I replaced the sediment bowl, gasket, and screen. When I tighten up the bowl no fuel will flow from the tank. When I loosen the retaining clip it allows the fuel to flow but obviously fuel then leaks over the top of the bowl. I've tried everything that I can think like removeing the fuel strainer and cleaning it, making sure there are no obstructions in the tank and lines etc. There's got to be something I'm missing along the way. Also the fuel flow problem happens with the gas cap on or off. So I'm running out of options. Thanks for the help!!!!!
MagMan
05-17-2005 05:37:18
 Re: Fuel Problems for '53 Cub in reply to Molly, 05-16-2005 18:59:41
That has happened on every tractor I have ever owned. you have to loosen it untill it fills up or open the plug on carb or take fuel line off. they get air locked onceit fills it should stay filled untill you run out of gas. If not try blowing compressed air back through the line while opening the valve maybe your tank petcock thingy is plugged. JON
George Willer
05-16-2005 19:16:41
Remove the plug on the bottom of the carburetor to check for good, continuous fuel flow. My money would bet the inlet screen in the carburetor is plugged.
George Willer
Molly
05-19-2005 07:41:21
 Re: Fuel Problems for '53 Cub in reply to George Willer, 05-16-2005 19:16:41
Oh the joys of technology. After I asked the question the computer went down. Now I have the answer I'll give 'em a try. Thanks again.
