Does anyone have any info on CE 135 power plants?
Adam D
05-17-2005 08:14:13
I have found a decent looking CE 135 International powerplant that I asked about the other day. Motor is stuck but did run about two years ago. What tractors used this motor? Looks like the equivalent of a farmall A B or C engine. What would it be worth? Also how much would it weigh as I would have to haul it home in my half ton pickup?
Thanks for any help
Adam D
Charles McNelly III
05-17-2005 18:35:42
 Re: Does anyone have any info on CE 135 power plan in reply to Adam D, 05-17-2005 08:14:13
I have been looking for one for awhile down here in south texas. The engine was in alot of tractors. It was in the 404 as well. If you put the bigger sleeves in I heard you can make 153ci. I want to put one in my B for pulling but you have to modify the crank and fan. The A and B only had a 113ci. engine and the super A and the super C had the 123ci. engine. The one you found was made much later.
farmall 340
05-17-2005 08:59:05
Depending on where it is and how much. I would like to have one to rebuild and swap out with mine. Im in MI Where is it How much
Farmer Bob
05-17-2005 08:51:16
I believe the IH/Farmall 340 gassers used the C135 engines.
chuck ore
05-17-2005 17:17:25
 Re: Does anyone have any info on CE 135 power plan in reply to Farmer Bob, 05-17-2005 08:51:16
330 UTE used the 135 as well
