Will rear weights from 240 fit Farmall A?
JohnG(TX)
05-31-2005 11:20:05
I will be going to the local scrap yard and can get a set of split weights from a 240(?). Will they fit a 1940 Farmall A?
CNKS
05-31-2005 11:31:57
 Re: Will rear weights from 240 fit Farmall A? in reply to JohnG(TX), 05-31-2005 11:20:05
No.
dr.sportster
05-31-2005 14:30:09
 Re: Will rear weights from 240 fit Farmall A? in reply to CNKS, 05-31-2005 11:31:57
I took a dumbell bar welded it to a peice of channel iron and stacked 90 lbs of steel weight lifters weights on that.Just that 90 lbs made a big difference.My A is very front heavy to begin with due to the snow plow on the front end.Traction improved 100 percent and it stopped getting stuck in little mudholes and wood chip piles.I actually have pulled right out of every situation with the added rear weight.This whole thing is bolted to the drawbar and still gives access to the trailer hitch on the drawbar.
dr.sportster
05-31-2005 14:31:39
 Re: Will rear weights from 240 fit Farmall A? in reply to dr.sportster, 05-31-2005 14:30:09
Oops posted that under CNKS by accident.
