Farmall B sickle mower.. lift-all?
othp
06-12-2005 07:30:30
I purchased a 5 foot mid mount sickle mower to use on my farmall B. I am having trouble figuring out how it lifts. It uses a cable and pulleys to lift the mower. What pulls on the cable. Am I missing a lever to lift it or was it hooked to the old cultivator exaust lift? If it is an exaust lift mower, were there many produced because I cannot find info on it anywhere.
ihkovas
06-12-2005 22:59:46
 Re: Farmall B sickle mower.. lift-all? in reply to othp, 06-12-2005 07:30:30
othp, I have a owners manual for that mower It is a No.18 Tractor Mower for the Farmall-A or International-A tractors. The round tube sticks up right behind the steering wheel with the exhaust lift rod going thru the tube. The A's are about 4 in narrower then the B so the mower torque tube that bolts above the drawbar on right hand side may not fir right. The two main problems I see is the B don't have the mounting bracket behind the steering gearbox for the end of the exhaust lift cyclinder(where the front cultivators fit on the Farmall A) and the tractor would be tip-over prone with the narrow front.
othp
06-12-2005 12:28:04
pic posted in Implement photos under "farmall sickle mower"
Jim Becker
06-12-2005 07:36:03
I don't believe IH made a mid-mount sickle bar mower for the B. Could it be a highway mower for the International A? Have any pictures?
Karl Hamson
06-12-2005 13:40:13
 Re: Farmall B sickle mower.. lift-all? in reply to Jim Becker, 06-12-2005 07:36:03
I have a 5 foot sickle bar mower in my Super A. It was missing all the lift apparatus so I figured out a cable lift which works fine but I have to chain it up in the transport position. It does not look anything like the one in your photo as mine has the pitman drive in the centre of the tractor. I have no idea what model it is, only that it is IH.
Jim Becker
06-18-2005 10:43:07
 Re: Farmall B sickle mower.. lift-all? in reply to Karl Hamson, 06-12-2005 13:40:13
Yours may be a #22 for the Super A.
